Ana içeriğe geç
Anker Soundcore Motion Boom Plus Tweeter Replacement
Neye ihtiyacın var
  1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: adım 1, 3 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: adım 1, 3 resimden 2. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: adım 1, 3 resimden 3.
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    FixBot'a Sor
    Yorum Ekle
  2. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 2, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 2, 2 resimden 2.
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    FixBot'a Sor
    Yorum Ekle
  3. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 3, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 3, 2 resimden 2.
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 4, 3 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 4, 3 resimden 2. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 4, 3 resimden 3.
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    FixBot'a Sor
    Yorum Ekle
  5. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 5, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 5, 2 resimden 2.
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  6. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 6, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 6, 2 resimden 2.
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    FixBot'a Sor
    Yorum Ekle
  7. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 7, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 7, 2 resimden 2.
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    FixBot'a Sor
    Yorum Ekle
  8. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 8, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 8, 2 resimden 2.
    • Remove the four 14 mm Philips screws on the top of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 9, 1 resimden 1.
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    FixBot'a Sor
    Yorum Ekle
  10. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 10, 3 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 10, 3 resimden 2. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 10, 3 resimden 3.
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    FixBot'a Sor
    Yorum Ekle
  11. Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: adım 11, 2 resimden 1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: adım 11, 2 resimden 2.
    • Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
    • Avoid pulling too hard on the ribbon cables as they are fragile and easily break.
    FixBot'a Sor
    Yorum Ekle
  12. Anker Soundcore Motion Boom Plus Tweeter Replacement: adım 12, 1 resimden 1.
    • Push the tweeters from the front side, and the tweeters should pop out. Remove and replace the tweeters with new ones.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
988 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-7, Botvin Spring 2025 UMass Dartmouth, Team 3-7, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G7
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 298
