Ana içeriğe geç
Anki Vector Battery Replacement
Neye ihtiyacın var
    1. Anki Vector  Battery Replacement, LCD Facial Display: adım 1, 3 resimden 1. Anki Vector  Battery Replacement, LCD Facial Display: adım 1, 3 resimden 2. Anki Vector  Battery Replacement, LCD Facial Display: adım 1, 3 resimden 3.
      • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
      • Repeat this step on the other side.
      • The panel should pop off without much force.
      FixBot'a Sor
      Yorum Ekle
    2. Anki Vector  Battery Replacement: adım 2, 3 resimden 1. Anki Vector  Battery Replacement: adım 2, 3 resimden 2. Anki Vector  Battery Replacement: adım 2, 3 resimden 3.
      • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
      • Lightly turn the spudger to separate the plate from Vector's head.
      • Work the spudger around the plate until it comes off.
      • Repeat this step on the the other side.
      FixBot'a Sor
      Yorum Ekle
    3. Anki Vector  Battery Replacement: adım 3, 2 resimden 1. Anki Vector  Battery Replacement: adım 3, 2 resimden 2.
      • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
      • Repeat this step on the opposite side.
      FixBot'a Sor
      Yorum Ekle
    4. Anki Vector  Battery Replacement: adım 4, 2 resimden 1. Anki Vector  Battery Replacement: adım 4, 2 resimden 2.
      • Pull apart Vector's head. It should separate down the middle.
      • Remove the screen protector by gently pulling it free from the two face halves.
      FixBot'a Sor
      Yorum Ekle
    5. Anki Vector  Battery Replacement: adım 5, 3 resimden 1. Anki Vector  Battery Replacement: adım 5, 3 resimden 2. Anki Vector  Battery Replacement: adım 5, 3 resimden 3.
      • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
      • Pull the LCD and speaker assembly from Vector's head.
      • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
      FixBot'a Sor
      Yorum Ekle
    1. Anki Vector  Battery Replacement, Battery: adım 6, 3 resimden 1. Anki Vector  Battery Replacement, Battery: adım 6, 3 resimden 2. Anki Vector  Battery Replacement, Battery: adım 6, 3 resimden 3.
      • Gently pull out the two halves of Vector's head from between his arms.
      FixBot'a Sor
      Yorum Ekle
    2. Anki Vector  Battery Replacement: adım 7, 3 resimden 1. Anki Vector  Battery Replacement: adım 7, 3 resimden 2. Anki Vector  Battery Replacement: adım 7, 3 resimden 3.
      • Remove the Anki Vector's belts on both sides of its body by gently sliding them off.
      • You should be able to pull them off without much effort.
      FixBot'a Sor
      Yorum Ekle
    3. Anki Vector  Battery Replacement: adım 8, 2 resimden 1. Anki Vector  Battery Replacement: adım 8, 2 resimden 2.
      • Pull off the covers attached to Vector's rear wheels.
      FixBot'a Sor
      Yorum Ekle
    4. Anki Vector  Battery Replacement: adım 9, 3 resimden 1. Anki Vector  Battery Replacement: adım 9, 3 resimden 2. Anki Vector  Battery Replacement: adım 9, 3 resimden 3.
      • Unscrew the 2 mm screws located under the wheel covers using a Phillips #0 screwdriver.
      • Remove the rear wheel.
      FixBot'a Sor
      Yorum Ekle
    5. Anki Vector  Battery Replacement: adım 10, 3 resimden 1. Anki Vector  Battery Replacement: adım 10, 3 resimden 2. Anki Vector  Battery Replacement: adım 10, 3 resimden 3.
      • Unscrew the two 2 mm body screws using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Anki Vector  Battery Replacement: adım 11, 3 resimden 1. Anki Vector  Battery Replacement: adım 11, 3 resimden 2. Anki Vector  Battery Replacement: adım 11, 3 resimden 3.
      • Using two fingers gently pull off the lower rear panel.
      • Using your fingers, unplug the ribbon connector.
      FixBot'a Sor
      Yorum Ekle
    7. Anki Vector  Battery Replacement: adım 12, 3 resimden 1. Anki Vector  Battery Replacement: adım 12, 3 resimden 2. Anki Vector  Battery Replacement: adım 12, 3 resimden 3.
      • Unscrew the two screws behind vector's neck.
      • Remove the capacitive touch assembly.
      FixBot'a Sor
      Yorum Ekle
    8. Anki Vector  Battery Replacement: adım 13, 2 resimden 1. Anki Vector  Battery Replacement: adım 13, 2 resimden 2.
      • With a moderate amount of force pull one of vector's top arms away from his body until it disconnects from the shaft.
      FixBot'a Sor
      Yorum Ekle
    9. Anki Vector  Battery Replacement: adım 14, 2 resimden 1. Anki Vector  Battery Replacement: adım 14, 2 resimden 2.
      • Gripping the shaft with needle nosed pliers, pull the opposite top arm off the main shaft.
      FixBot'a Sor
      Yorum Ekle
    10. Anki Vector  Battery Replacement: adım 15, 3 resimden 1. Anki Vector  Battery Replacement: adım 15, 3 resimden 2. Anki Vector  Battery Replacement: adım 15, 3 resimden 3.
      • Pinch one end of the arm shaft and push it into the body.
      • Grab the other end and pull the shaft out of the body.
      FixBot'a Sor
      Yorum Ekle
    11. Anki Vector  Battery Replacement: adım 16, 3 resimden 1. Anki Vector  Battery Replacement: adım 16, 3 resimden 2. Anki Vector  Battery Replacement: adım 16, 3 resimden 3.
      • Raise vectors arms all the way up and gently pull each arm out of its socket.
      FixBot'a Sor
      Yorum Ekle
    12. Anki Vector  Battery Replacement: adım 17, 2 resimden 1. Anki Vector  Battery Replacement: adım 17, 2 resimden 2.
      • Pull the wheel covers off of Vectors forward wheels.
      FixBot'a Sor
      Yorum Ekle
    13. Anki Vector  Battery Replacement: adım 18, 3 resimden 1. Anki Vector  Battery Replacement: adım 18, 3 resimden 2. Anki Vector  Battery Replacement: adım 18, 3 resimden 3.
      • Using the same Phillips #0 screwdriver, unscrew the 2 mm screw under the wheel cover.
      • Gently pull the wheel off.
      FixBot'a Sor
      Yorum Ekle
    14. Anki Vector  Battery Replacement: adım 19, 3 resimden 1. Anki Vector  Battery Replacement: adım 19, 3 resimden 2. Anki Vector  Battery Replacement: adım 19, 3 resimden 3.
      • Unscrew the two body screws located behind the front wheels.
      • Gently pull the cover from Vector's body
      • Be careful when removing the cover. The infrared sensor connects the cover to the body by wires.
      FixBot'a Sor
      Yorum Ekle
    15. Anki Vector  Battery Replacement: adım 20, 3 resimden 1. Anki Vector  Battery Replacement: adım 20, 3 resimden 2. Anki Vector  Battery Replacement: adım 20, 3 resimden 3.
      • Gently unplug and remove the infrared sensor.
      FixBot'a Sor
      Yorum Ekle
    16. Anki Vector  Battery Replacement: adım 21, 3 resimden 1. Anki Vector  Battery Replacement: adım 21, 3 resimden 2. Anki Vector  Battery Replacement: adım 21, 3 resimden 3.
      • Insert your Phillips #0 bit into a 4 mm nut driver and insert both into your bit driver.
      • Unscrew the three body screws.
      FixBot'a Sor
      Yorum Ekle
    17. Anki Vector  Battery Replacement: adım 22, 2 resimden 1. Anki Vector  Battery Replacement: adım 22, 2 resimden 2.
      • Gradually increasing applied force, pull the body apart.
      FixBot'a Sor
      Yorum Ekle
    18. Anki Vector  Battery Replacement: adım 23, 3 resimden 1. Anki Vector  Battery Replacement: adım 23, 3 resimden 2. Anki Vector  Battery Replacement: adım 23, 3 resimden 3.
      • Remove the shoulder panel.
      • Remove the weight.
      FixBot'a Sor
      Yorum Ekle
    19. Anki Vector  Battery Replacement: adım 24, 3 resimden 1. Anki Vector  Battery Replacement: adım 24, 3 resimden 2. Anki Vector  Battery Replacement: adım 24, 3 resimden 3.
      • Unplug the two motor connectors from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    20. Anki Vector  Battery Replacement: adım 25, 3 resimden 1. Anki Vector  Battery Replacement: adım 25, 3 resimden 2. Anki Vector  Battery Replacement: adım 25, 3 resimden 3.
      • Wriggle the battery free from the motherboard.
      • Using a soldering iron, desolder the connections from the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
Shay Takei
1.831 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G6
4 Üyeler
10 adet Kılavuz yazıldı
25Kılavuz Yorumları
Ok nice step by step guide but what are the specs for the battery as they’re not visable in any of the pictures…
John Fitzgerald - Yanıt Paylaş
Part Number: Li-Ion Poly 500mAh #1578B
3.7V 500mAh
Brian - Yanıt Paylaş
Who manages to do all of this in 7 minutes ? Apparently it is a 3.7V battery, question is what is the max size that fits ? 3.5 x 2.5 x 0.4 cm is reported to fit, 4x3x0.5 might as well.
Holger Brueckner - Yanıt Paylaş
Any idea where to get one ?
Gordon Hamilton - Yanıt Paylaş
Who manages to do all of this is 7 minutes?
me
Kerigan Creighton - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 107
Son 30 gün: 401
Her zaman: 34,789
