Ana içeriğe geç
Anki Vector LCD Facial Display Replacement
Neye ihtiyacın var
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: adım 1, 3 resimden 1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: adım 1, 3 resimden 2. Anki Vector LCD Facial Display Replacement, LCD Facial Display: adım 1, 3 resimden 3.
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: adım 2, 3 resimden 1. Anki Vector LCD Facial Display Replacement: adım 2, 3 resimden 2. Anki Vector LCD Facial Display Replacement: adım 2, 3 resimden 3.
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: adım 3, 2 resimden 1. Anki Vector LCD Facial Display Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: adım 4, 2 resimden 1. Anki Vector LCD Facial Display Replacement: adım 4, 2 resimden 2.
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: adım 5, 3 resimden 1. Anki Vector LCD Facial Display Replacement: adım 5, 3 resimden 2. Anki Vector LCD Facial Display Replacement: adım 5, 3 resimden 3.
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Shay Takei
1.777 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G6
4 Üyeler
10 adet Kılavuz yazıldı
26Kılavuz Yorumları
Any idea where to get the proper displays ?
Holger Brueckner - Yanıt
xenojin - Yanıt
This is great information, but where can I buy the display?
Jackie Fischvogt - Yanıt
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 129
Her zaman: 12,181
