Giriş
If you are experiencing dysfunctional buttons on the side of the brush, this guide will walk you through on how to take apart the brush in order to replace these buttons. Soldering is involved, so if you don't know how to solder take a look at this How To Solder and Desolder Connections
Neye ihtiyacın var
Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
You may have to bend the dark red capacitor out of the way to reach the soldering points.
Bir başkası bu kılavuzu tamamladı.
