Ana içeriğe geç
Apalus Digital Hair Straightening Brush LCD Screen Replacement
Neye ihtiyacın var
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 2, 1 resimden 1.
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 3, 1 resimden 1.
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 5, 1 resimden 1.
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 6, 1 resimden 1.
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 7, 2 resimden 1. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 7, 2 resimden 2.
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 8, 2 resimden 1. Apalus Digital Hair Straightening Brush LCD Screen Replacement: adım 8, 2 resimden 2.
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
Sonuç
Malak
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 527
