Ana içeriğe geç
Apple AirPort Extreme Model A1143 Logic Board Replacement
Zak
Zak ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
1 - 2 dakika
Kolay
This is another guide that will be used for several repairs. The logic board is the most frequently replaced part for this device as individual parts are hard to come by.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Pad: adım 1, 1 resimden 1.
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Cover: adım 2, 1 resimden 1.
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Logic Board Replacement: adım 3, 1 resimden 1.
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove from Case: adım 4, 1 resimden 1.
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Logic Board Replacement, Detach Logic Board From Case: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Logic Board Replacement, Pull Back Tabs: adım 6, 1 resimden 1.
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove Metal case: adım 7, 1 resimden 1.
    • Carefully pull the metal case away from the logic board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zak
616 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G4
5 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
my apple a1143 wont turn on at all no light.
what can it be done?
Gabriel barradenguy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,672
