Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Apple Powerbook 520 Floppy Drive Replacement
Neye ihtiyacın var
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: adım 1, 1 resimden 1.
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: adım 2, 1 resimden 1.
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: adım 3, 1 resimden 1.
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: adım 4, 1 resimden 1.
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: adım 5, 1 resimden 1.
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: adım 6, 1 resimden 1.
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: adım 7, 1 resimden 1.
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: adım 8, 1 resimden 1.
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kevin Peters
130 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G66
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 2,714
