Giriş
This Guide Picks up after the Battery and Screen Removal guides posted, all of the same tools are used.
Undo both connectors highlighted.
Then the Taptic engine should be able to be lifted out.
Remove the speaker slowly.
4 more Tri-screws are removed here.
Gently pulling back the screen flex cables reveals 2 more Tri-screws that should be removed.
Then the brackets can be removed with tweezers.
Remove these 2 Tri-screws.
After taking off the first bracket, take of the next Tri-screw and remove the second bracket.
Starting in the bottom right corner as show here. Gently wedge in a spudger and pry up on the board.
Once you are able to get a good hold on the board move try pulling down and to the right in a clockwork motion.
Once the board is lifted out, the final connector is highlighted.
Disconnect and you are all done!
Repeat steps backwards to put everything back together.
