Ana içeriğe geç
Apple Watch Series 4 Screen Replacement
Neye ihtiyacın var
  1. Apple Watch Series 4 Screen Replacement, Display Opening: adım 1, 2 resimden 1. Apple Watch Series 4 Screen Replacement, Display Opening: adım 1, 2 resimden 2.
    Hi. I changed the screen on an apple watch series 4, now the screen works, whcih is great, but when I charge it, the green snake comes on but never charges. It heats up the bottom, gets very warm. Could it be the battery itself? Maybe needs a new one? Is rthere anything else that woudl be causing the battery to not charge and or heat up on the bottom when chaging the screen?
    Derrick Brewer - Yanıt
  2. Apple Watch Series 4 Screen Replacement, Safety Requirements: adım 2, 3 resimden 1. Apple Watch Series 4 Screen Replacement, Safety Requirements: adım 2, 3 resimden 2. Apple Watch Series 4 Screen Replacement, Safety Requirements: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Safety Glasses
    $3.19
    Satın Al
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 4 Screen Replacement: adım 3, 1 resimden 1.
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  4. Apple Watch Series 4 Screen Replacement: adım 4, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 4, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 4, 3 resimden 3.
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
  5. Apple Watch Series 4 Screen Replacement: adım 5, 2 resimden 1. Apple Watch Series 4 Screen Replacement: adım 5, 2 resimden 2.
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 4 Screen Replacement: adım 6, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 6, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 6, 3 resimden 3.
    • It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
  7. Apple Watch Series 4 Screen Replacement: adım 7, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 7, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 7, 3 resimden 3.
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
    • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
  8. Apple Watch Series 4 Screen Replacement, Battery: adım 8, 2 resimden 1. Apple Watch Series 4 Screen Replacement, Battery: adım 8, 2 resimden 2.
    • Carefully fold the screen to the back until you get enough space to pry out the battery.
    • Avoid tensioning the display cables when folding the screen to the back.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
    If you are just replacing the screen then there is no need to remove battery.
    anonymous 1930 - Yanıt
    When removing the screen I tore the two outer cables attached to the lcd screen. What are their purpose? I read somewhere they are just some sort of shield. Will my watch function normally without them?
    thanks
    Mike Bahlman - Yanıt
  9. Apple Watch Series 4 Screen Replacement: adım 9, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 9, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 9, 3 resimden 3.
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
    • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Apple Watch Series 4 Screen Replacement: adım 10, 2 resimden 1. Apple Watch Series 4 Screen Replacement: adım 10, 2 resimden 2.
    • Carefully lift the battery and bring it in a 75° angle.
    • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
  11. Apple Watch Series 4 Screen Replacement: adım 11, 1 resimden 1.
    • Remove the Y000 screw (1.2 mm length).
  12. Apple Watch Series 4 Screen Replacement: adım 12, 2 resimden 1. Apple Watch Series 4 Screen Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to remove the metal plate which covers the battery connector.
  13. Apple Watch Series 4 Screen Replacement: adım 13, 2 resimden 1. Apple Watch Series 4 Screen Replacement: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
  14. Apple Watch Series 4 Screen Replacement: adım 14, 2 resimden 1. Apple Watch Series 4 Screen Replacement: adım 14, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    Satın Al
    • Remove the battery.
    • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  15. Apple Watch Series 4 Screen Replacement, Screen Removal: adım 15, 2 resimden 1. Apple Watch Series 4 Screen Replacement, Screen Removal: adım 15, 2 resimden 2.
    • The black foil which covers the display connectors is very fragile and likely to rip. To keep the tape intact while peeling it off, it's necessary to use high isopropyl alcohol or an iOpener.
    • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip and apply it to the black adhesive foil. Let it penetrate the adhesive for about two minutes.
    • Alternatively you can place an a heated iOpener on top of the screen to loosen the adhesive. Apply the iOpener at least for two minutes.
  16. Apple Watch Series 4 Screen Replacement: adım 16, 1 resimden 1.
    • Use a pair of tweezers to carefully peel off the tape covering the three display cable connectors.
  17. Apple Watch Series 4 Screen Replacement: adım 17, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 17, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 17, 3 resimden 3.
    • Use one arm of a pair of tweezers to carfully open the three ZIF connectors on the rear side of the screen.
  18. Apple Watch Series 4 Screen Replacement: adım 18, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 18, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 18, 3 resimden 3.
    • Use a pair of blunt nose tweezers to peel up the sides of the black foil which adheres the cable to the rear side of the screen.
  19. Apple Watch Series 4 Screen Replacement: adım 19, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 19, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 19, 3 resimden 3.
    • Lift the body of the watch up and carefully slide a spudger underneath the display flex cable to loosen remaining adhesive.
  20. Apple Watch Series 4 Screen Replacement: adım 20, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 20, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 20, 3 resimden 3.
    • Carefully pull the display flex cables out of their ZIF connectors.
    • Make sure to hold on to the display flex cable during this procedure and avoid pulling only on the body of the watch. Otherwise the display cable might rip.
    • Separate the watch assembly and the screen.
  21. Apple Watch Series 4 Screen Replacement, Screen: adım 21, 3 resimden 1. Apple Watch Series 4 Screen Replacement, Screen: adım 21, 3 resimden 2. Apple Watch Series 4 Screen Replacement, Screen: adım 21, 3 resimden 3.
    Adhesive Cleanup Kit (Set of 12)
    Satın Al
    • The following steps describe how to apply replacement adhesive before reassembling your watch.
    • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on top of the Force Touch gasket.
  22. Apple Watch Series 4 Screen Replacement: adım 22, 1 resimden 1.
    • Use a pair of tweezers to carefully remove the replacement adhesive with the blue protective film from the backing paper.
  23. Apple Watch Series 4 Screen Replacement: adım 23, 3 resimden 1. Apple Watch Series 4 Screen Replacement: adım 23, 3 resimden 2. Apple Watch Series 4 Screen Replacement: adım 23, 3 resimden 3.
    • Hold the replacement adhesive diagonally to thread it over the display cable.
    • Position the replacement adhesive on top of the Force Touch gasket.
  24. Apple Watch Series 4 Screen Replacement: adım 24, 1 resimden 1.
    • Use the pointed end of a spudger to make final position adjustments and press the adhesive into place.
    Don’t remove the blue protective film until you’ve got the screen connected to the ribbon cables. You’ll almost guaranteed to need a third hand to get the ribbon cable back in. Don’t forget to flip up the connector locks on the case side and flip them back down after inserting the cable.
Sonuç
To reassemble your Apple Watch Series 4 follow these instructions in reverse order to reattach the screen and the battery.
34 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.353 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
17 Yorum
Do not buy does not come with all the pieces needed to make the screen repair all the connections are not possible
jachs780 - Yanıt
Can you tell me what the black adhesive tape with flex ends that covers the flex ribbons is used for and can it be replaced ?
Sheila Blackwell - Yanıt
That is for shielding and grounding purposes. If you get a spare you can of course replace it. But be careful not to damage the display cables.
Tobias Isakeit -
Sheila, this you can purchase on Aliexpress. i tried to get it elsewhere, seems noone else stocks it. cost approx $10. i found it here: https://www.aliexpress.com/item/10050019...
palokiller -
I have replaced an original screen from another apple watch and everything seems to have gone well. But when I try to pair with the iphone it doesn't succeed. Is it because I didn't put the NFC chip from the original apple watch? What can be?.
It is an apple watch series 4 44 mm + cellular.
Thank you very much.
ihsack - Yanıt
I would like to change the screen of my smart watch series 4. Could you tell me all the tools I need? Will the battery I have stop working? Thank you.
Asiel AD - Yanıt
Do you have to replace the black flex ribbons when preparing the apple watch or can you leave them out?
Meghan McNeely - Yanıt
Very difficult repair, indeed. Be very careful about the side wires, they can be very easily be cut when opening the screen. I just hope having a contact supper to supper will be enough… Response in some hours.
This tutorial could be completed with an advice about how to bring the screen wires back to their connectors. That was the most difficult part for me. I was afraid to cut or destroy them.
Concerning the parts, I found the adhesive ring very thick compare to the adhesive I had to remove. What I had as parts did not correspond to what was shown in the repair tutorial. The watch is getting pressed now so I can’t judge if the adhesive is ok or too thick.
It was also very difficult to separate to only get the ring.
Anyway, thanks for this tutorial. Without it, impossible to repair the first time.
panazyde - Yanıt
Sorry for replying after such a long time: I have cut the smaller side wires (both, I'm very proud of myself ;) ), did you have any problems using the watch with such wires cut? It seems very difficult to find replacement parts for such components.
matbottin -
Replaced screen and testing before closing everything back up. Screen comes on, but it doesn’t respond to touch. Is this due to a cable not connecting properly, or is this a bad screen? Comes on and looks great, but not touch responsive. -dw
Andrew - Yanıt
Hi Andrew, yes, there might be a cable not sitting correctly in its connector. Those tiny cables are hard to handle and need to be inserted all the way in their connectors. Hopefully that solves the issue.
Tobias Isakeit -
Quick question: the two wire cables at the sides of the black foil (Step 18) are of any use? I have broken mine (both) while opening the watch, and I am wondering if I have to throw everything in the garbage (I was replacing the battery) or I can still use the watch after battery replacement (I have to order the battery yet)
matbottin - Yanıt
Pareil les 3 connecteurs impeccable mais un des deux stickers aux extrémités s'est cassé ... Est-ce pour cela que ma montre ne s'allume pas ?
Baptiste LUCK -
Bonjour, j'ai respecté toutes les étapes une par une ... Et rien ne se passe dans ma montre ... Montre non utilisée pendant plus d'un an du coup j'ai choisi de changer la batterie ... Rien de plus ... La montre "chauffe" donc la charge semble fonctionner mais l'écran est noir et aucun éclair ou autre a l'écran ^^
Baptiste LUCK - Yanıt
Are there any news on Apple Pay function after replacing the screen? As I can remember at some time there was a disclaimer at this guide that there is currently no easy fix to get NFC and Apple Pay working after replacement. I thought if only changing the screen it's 100% not working but now it sounds like it could succeed or not. Is that right?
Albert - Yanıt
We haven’t tested it recently. So all we can say is in the introduction:
"Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed."
Tobias Isakeit -
Oh boy I'm not exited for this repair... Hopefully it goes well...
Crosby Grim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 51
Son 7 gün: 390
Son 30 gün: 1,791
Her zaman: 131,763
