Ana içeriğe geç
Archos 97 Carbon Speakers Replacement
Neye ihtiyacın var
  1. Archos 97 Carbon Speakers Replacement, Speakers: adım 1, 1 resimden 1.
    • Pry the tablet open in the corner using an opening tool.
    • Start in the top left corner and continue clockwise until the two pieces are separated.
  2. Archos 97 Carbon Speakers Replacement: adım 2, 3 resimden 1. Archos 97 Carbon Speakers Replacement: adım 2, 3 resimden 2. Archos 97 Carbon Speakers Replacement: adım 2, 3 resimden 3.
    • Remove the tape and plug connecting the cable to the tab, and it will come loose.
    • This will loosen the cable connecting the screen to the interior of the tablet.
  3. Archos 97 Carbon Speakers Replacement: adım 3, 2 resimden 1. Archos 97 Carbon Speakers Replacement: adım 3, 2 resimden 2.
    • Remove the black tape from the silver cable connecting the screen to the motherboard on the left side of the tablet.
    • This will loosen the gold plug.
  4. Archos 97 Carbon Speakers Replacement: adım 4, 1 resimden 1.
    • Once you have separated the the screen from the tablet, you can place the screen to the side. You should be looking at this part of the tablet.
    • These are the speakers.
  5. Archos 97 Carbon Speakers Replacement: adım 5, 3 resimden 1. Archos 97 Carbon Speakers Replacement: adım 5, 3 resimden 2. Archos 97 Carbon Speakers Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • Desolder each of the three wires to detach the speaker wires from the tablet.
    • There are three wires that you will desolder from the motherboard. One is red, one is black, and one is white.
    • We recommend that you use a solder sucker to suck up any of the residue that the solder produces.
  6. Archos 97 Carbon Speakers Replacement: adım 6, 2 resimden 1. Archos 97 Carbon Speakers Replacement: adım 6, 2 resimden 2.
    • Pry each of the speakers up with an opening tool.
    • Remove the speakers and their connected wires from the tablet.
Sonuç
You have now successfully replaced the internal speakers for your Archos 97 yourself. And now you understand the process for accessing and potentially repairing/replacing any other internal components in the future should the need arise.
Bir başkası bu kılavuzu tamamladı.
Allyson Seber
311 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 461
