Ana içeriğe geç
Arlo Pro 2 Camera Lens Replacement
Neye ihtiyacın var
  1. Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: adım 1, 3 resimden 1. Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: adım 1, 3 resimden 2. Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: adım 1, 3 resimden 3.
    • Press the release button on the camera and gently pull apart the casing to open the device.
    • Remove the battery from inside the case.
    FixBot'a Sor
    Yorum Ekle
  2. Arlo Pro 2 Camera Lens Replacement: adım 2, 3 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 2, 3 resimden 2. Arlo Pro 2 Camera Lens Replacement: adım 2, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
    • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
    FixBot'a Sor
    Yorum Ekle
  3. Arlo Pro 2 Camera Lens Replacement: adım 3, 3 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 3, 3 resimden 2. Arlo Pro 2 Camera Lens Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
    • Seperate the daughterboards from the motherboard and camera casing.
    FixBot'a Sor
    Yorum Ekle
  4. Arlo Pro 2 Camera Lens Replacement: adım 4, 3 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 4, 3 resimden 2. Arlo Pro 2 Camera Lens Replacement: adım 4, 3 resimden 3.
    • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
    • Carefully pull the motherboard apart from the camera casing.
    FixBot'a Sor
    Yorum Ekle
  5. Arlo Pro 2 Camera Lens Replacement: adım 5, 2 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 5, 2 resimden 2.
    • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
    FixBot'a Sor
    Yorum Ekle
  6. Arlo Pro 2 Camera Lens Replacement, Camera Lens: adım 6, 2 resimden 1. Arlo Pro 2 Camera Lens Replacement, Camera Lens: adım 6, 2 resimden 2.
    • Use a Philips #00 screwdriver to remove the four 4 mm screws on the back metal plate holding the daughterboards together.
    FixBot'a Sor
    Yorum Ekle
  7. Arlo Pro 2 Camera Lens Replacement: adım 7, 2 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 7, 2 resimden 2.
    • Slide out a small metal retainer bracket from in between the daughterboards.
    FixBot'a Sor
    Yorum Ekle
  8. Arlo Pro 2 Camera Lens Replacement: adım 8, 2 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 8, 2 resimden 2.
    • Pull apart the daughterboard containing LEDs from the other daughterboard.
    FixBot'a Sor
    Yorum Ekle
  9. Arlo Pro 2 Camera Lens Replacement: adım 9, 2 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 9, 2 resimden 2.
    • Separate the daughterboard containing the camera piece from the metal backing.
    FixBot'a Sor
    Yorum Ekle
  10. Arlo Pro 2 Camera Lens Replacement: adım 10, 3 resimden 1. Arlo Pro 2 Camera Lens Replacement: adım 10, 3 resimden 2. Arlo Pro 2 Camera Lens Replacement: adım 10, 3 resimden 3.
    • Use a Philips #00 screwdriver to remove the two 5 mm screws on the back of the camera daughterboard to disconnect the camera piece from the daughterboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Botvin Spring 2025 UMass Dartmouth, Team 2-2, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 56
Her zaman: 346
