Ana içeriğe geç
Arlo Pro 2 Camera Micro-USB Port Replacement
Neye ihtiyacın var
  1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: adım 1, 3 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: adım 1, 3 resimden 2. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: adım 1, 3 resimden 3.
    • Press the release button on the camera and gently pull apart the casing to open the device.
    • Remove the battery from inside the case.
    FixBot'a Sor
    Yorum Ekle
  2. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 2, 3 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 2, 3 resimden 2. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 2, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
    • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
    FixBot'a Sor
    Yorum Ekle
  3. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 3, 3 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 3, 3 resimden 2. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
    • Seperate the daughterboards from the motherboard and camera casing.
    FixBot'a Sor
    Yorum Ekle
  4. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 4, 3 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 4, 3 resimden 2. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 4, 3 resimden 3.
    • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
    • Carefully pull the motherboard apart from the camera casing.
    FixBot'a Sor
    Yorum Ekle
  5. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 5, 2 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 5, 2 resimden 2.
    • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
    FixBot'a Sor
    Yorum Ekle
  6. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: adım 6, 2 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: adım 6, 2 resimden 2.
    • Thread the wires of the Micro-USB port through the casing.
    • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
    FixBot'a Sor
    Yorum Ekle
  7. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 7, 3 resimden 1. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 7, 3 resimden 2. Arlo Pro 2 Camera Micro-USB Port Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
    • Gently remove the Micro-USB port by pulling it away from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Botvin Spring 2025 UMass Dartmouth, Team 2-2, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G2
3 Üyeler
1Rehber Yorum
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 47
Her zaman: 372
