Artemide Tolomeo switch replacement
Giriş
1. adıma gitAfter a few thousand switching operations, the switch of a Tolomeo may no longer function properly. The unit of switch and lamp holder is available from Artemide as a spare part. These instructions show you how to replace it.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Unscrew the Phillips screw on the clamp. You may have to hold the nut on the opposite side.
Carefully press the clamp apart, using a suitable tool if necessary.
Lift the flanged edge of the lampshade out of the clamp.
Remove the lampshade.
Bei mir war die Spannzwinge so alt, dass sie schon zerbrach, als ich sie den ersten Millimeter auseinandergedrückt habe.
Habe zähneknirschend das ganze Gabelgelenk mit Spannzwinge bestellt. Bei mittelicht DE waren das 28,42 + 4,20 Versand.Immerhin gut zu wissen, dass man sie nachkaufen kann.
VauWeh -
The socket is fixed at the top with a wide ring. This ring is secured against unscrewing by a small brass catch.
Press the brass catch with a small flat-blade screwdriver about 1 mm toward the center of the socket. Do not bend the brass catch too much.
Then unscrew the wide ring on the lamp socket.
I’ve changed the switches on several of Tolomeo lamps with no problems.
Maybe 4 or 5 switches over time.
They’ve clearly changed the design, because the one the I’m trying to fix now has this pivoting thing.
However, it’s impossible to unscrew the socket.
I love my Tolomeo lamps, but these switches have always been absolute garbage.
Somehow, they managed to make them even worse.
Now it’ll cost me over $100 to ship it to Artemide for repair AND no lamp for at least a month.
Great.
Here is a picture of the switch. You can buy the complete set quite expensive from Artemide, because the socket has been machined by hand. This has the advantage that you can also renew the socket.
You may also find the switch on its own, which is cheaper. It is a snap-in rocker switch with screw connection. The cutout size is 20 x 14 mm, 15 mm installation depth from the frame. The frame is 3 mm high with the dimensions 26x16 mm. This one could fit.
ich konnte den Schalter reparieren, indem ich die Wippe vorsichtig herausgehebelt habe. die inneren Kontakte waren verschmutzt und das u-förmige Schaltelement war zu sehr zusammengedrückt. nach dem reinigen (elektronik-reiniger) schaltet es wieder perfekt
In my case I didnt have to replace. I opened the plactic part of the switch, there is a small thin metal plate. Take it out, clean the contact and bend it a little bit, put it back. Now it works again.
Super Anleitung...und der empfohlene Kippschalter passt und funktioniert. Kosten: 4.95 plus Porto. Original Schalter momentan 30€. Herzlichen Dank!
Work through the steps in reverse order to reassemble your device.
10 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
14 Yorum
Thanks for the article. When I get to step 5, I don't see an Allen screw. See the linked images. Do you know how I would remove the cable from the socket?
Thanks!
One more photo:
Socket photo 3
OK, I figured it out, needed to press down on the metal clip in photo 3.
John E. -
Fixed with a white switch.
New white switch.
John E. -
Well done, like it.
VauWeh -
Thanks for hte comment!
John E. -
It worked! Thanks
Thank you so much for taking the time to compile this @vauweh ! Super greatful. It took me approx. 1 hour including getting all tools together, set it up, repair it and clean the desk.
The recommended Amazon switch worked well (<5 EUR). My Tolomeo was bought around 2020 or so. It took me a while to figure out step 4.
In my case I needed to press the lever on the outer diameter down so that the big ring can rotate over the lever. More light helped to see the mechanism (bad luck if your lamp is broken!).
My original issue was that my Tolomeo randomly turned off but not on again. It sometimes took a couple of days until it turned on again. Then after a couple of minutes it turned off again. Right now it seems to work with the new switch. So thank you for explaining how the repair works!
Didn't find the switch on "SF Craigslist".
Microsoft AI returned the following. I've ordered two.
Only $1.05 each + $5.16 shipping!
https://grandbrass.com/snap-in-rocker-sw...
SKU: SW144B
Function: On/Off
Type: Switch - Fixture - Toggle
Color/ Finish: Black
Length: 1.000 (1in)
Height: 0.812 (13/16in)
Width: 0.625 (5/8in)
Voltage (Max): 125V, 250V
Certification: cRUus, ENEC
