Ana içeriğe geç
Astak Mole Antenna Replacement
Meshari Alkhelaiwi
Meshari Alkhelaiwi ve 5 diğer katkıda bulunanlar
En son February 27, 2021 tarihinde güncellendi
10 dakika
Orta
Yanlış Araçlar
Dilim ve Zar
If you getting a new antenna doesn't work, there might be a problem with the antenna connection inside the camera. This guide will show you how to replace input cable that attaches the antenna to the motherboard.
Neye ihtiyacın var
Aletler
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Astak Mole Antenna Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Antenna Replacement: adım 2, 1 resimden 1.
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Antenna Replacement: adım 3, 1 resimden 1.
    • Remove the SD card.
  4. Astak Mole Antenna Replacement: adım 4, 1 resimden 1.
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Antenna Replacement: adım 5, 1 resimden 1.
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Antenna Replacement, Antenna: adım 6, 2 resimden 1. Astak Mole Antenna Replacement, Antenna: adım 6, 2 resimden 2.
    • Unscrew the antenna in a counter-clockwise rotation.
  7. Astak Mole Antenna Replacement: adım 7, 1 resimden 1.
    • Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
    • Screw length: 5.3mm
  8. Astak Mole Antenna Replacement: adım 8, 1 resimden 1.
    • Gently pry open the circuit board attached to the antenna wire using a metal spudger.
  9. Astak Mole Antenna Replacement: adım 9, 1 resimden 1.
    • Remove the antenna female end from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Meshari Alkhelaiwi
143 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 513
