Ana içeriğe geç
Astro A40 TR Internal wiring components Replacement
Neye ihtiyacın var
  1. Astro A40 TR Internal wiring components Replacement, Speakers: adım 1, 2 resimden 1. Astro A40 TR Internal wiring components Replacement, Speakers: adım 1, 2 resimden 2.
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Internal wiring components Replacement: adım 2, 3 resimden 1. Astro A40 TR Internal wiring components Replacement: adım 2, 3 resimden 2. Astro A40 TR Internal wiring components Replacement: adım 2, 3 resimden 3.
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Internal wiring components Replacement: adım 3, 2 resimden 1. Astro A40 TR Internal wiring components Replacement: adım 3, 2 resimden 2.
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Internal wiring components Replacement: adım 4, 2 resimden 1. Astro A40 TR Internal wiring components Replacement: adım 4, 2 resimden 2.
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Internal wiring components Replacement: adım 5, 1 resimden 1.
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Internal wiring components Replacement, Internal wiring components: adım 6, 1 resimden 1.
    • Untie the disconnected wiring harness.
  7. Astro A40 TR Internal wiring components Replacement: adım 7, 1 resimden 1.
    • Pull the black wire out of the hole in the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mike
448 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-5, Martin Fall 2016 UMass Dartmouth, Team 6-5, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 8,050
