Ana içeriğe geç
Astro A50 2016 Headset Battery Replacement
Neye ihtiyacın var
  1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: adım 1, 2 resimden 1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: adım 1, 2 resimden 2.
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
    FixBot'a Sor
    Yorum Ekle
  2. Astro A50 2016  Headset Battery Replacement: adım 2, 1 resimden 1.
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Astro A50 2016  Headset Battery Replacement: adım 3, 1 resimden 1.
    • Remove the four 6mm Phillips 1 screws.
    FixBot'a Sor
    Yorum Ekle
  4. Astro A50 2016  Headset Battery Replacement: adım 4, 1 resimden 1.
    • Lift the speaker module up off the device.
    FixBot'a Sor
    Yorum Ekle
  5. Astro A50 2016  Headset Battery Replacement, Headset Battery: adım 5, 2 resimden 1. Astro A50 2016  Headset Battery Replacement, Headset Battery: adım 5, 2 resimden 2.
    • Remove the five 6mm PH1 screws.
    • Remove the buttons panel by pulling the panel away from the white ribbon cord.
    FixBot'a Sor
    Yorum Ekle
  6. Astro A50 2016  Headset Battery Replacement: adım 6, 2 resimden 1. Astro A50 2016  Headset Battery Replacement: adım 6, 2 resimden 2.
    • Remove the four 6mm PH1 screws.
    • Remove the tape holding the wires connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Astro A50 2016  Headset Battery Replacement: adım 7, 1 resimden 1.
    • Remove the back panel by squeezing the two tabs together and pushing out.
    FixBot'a Sor
    Yorum Ekle
  8. Astro A50 2016  Headset Battery Replacement: adım 8, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  9. Astro A50 2016  Headset Battery Replacement: adım 9, 1 resimden 1.
    • Remove the battery by using the plastic opening tool to pry it away from the headset.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Andrew Monson
505 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G1
3 Üyeler
18 adet Kılavuz yazıldı
15Kılavuz Yorumları
Is this for the Gen III Astro a50?
vic.bianco - Yanıt Paylaş
Yes it’s for the Gen 3 A50
Crisdavid - Yanıt Paylaş
Where do I buy a battery though….
Brandon Phillips - Yanıt Paylaş
how can I connect the new battery ?
Ahmed f - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 33
Son 30 gün: 180
Her zaman: 32,142
