Ana içeriğe geç
Astro Mixamp USB Port Replacement
Neye ihtiyacın var
  1. Astro Mixamp USB Port Replacement, Panel Dial: adım 1, 2 resimden 1. Astro Mixamp USB Port Replacement, Panel Dial: adım 1, 2 resimden 2.
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
    FixBot'a Sor
    Yorum Ekle
  2. Astro Mixamp USB Port Replacement: adım 2, 2 resimden 1. Astro Mixamp USB Port Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the spacer nuts and washers from each dial post.
    FixBot'a Sor
    Yorum Ekle
  3. Astro Mixamp USB Port Replacement, Outer Casing: adım 3, 2 resimden 1. Astro Mixamp USB Port Replacement, Outer Casing: adım 3, 2 resimden 2.
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  4. Astro Mixamp USB Port Replacement: adım 4, 1 resimden 1.
    • Use a screwdriver to remove the screw from the rear casing.
    FixBot'a Sor
    Yorum Ekle
  5. Astro Mixamp USB Port Replacement: adım 5, 1 resimden 1.
    • Gently lift the rear casing from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Astro Mixamp USB Port Replacement, Motherboard: adım 6, 3 resimden 1. Astro Mixamp USB Port Replacement, Motherboard: adım 6, 3 resimden 2. Astro Mixamp USB Port Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Astro Mixamp USB Port Replacement: adım 7, 1 resimden 1.
    • Gently pull the motherboard from the front cover.
    FixBot'a Sor
    Yorum Ekle
  8. Astro Mixamp USB Port Replacement, USB Port: adım 8, 3 resimden 1. Astro Mixamp USB Port Replacement, USB Port: adım 8, 3 resimden 2. Astro Mixamp USB Port Replacement, USB Port: adım 8, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hope Burns
741 İtibar
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
What port is used as a replacement?
jonescoleman1738 - Yanıt Paylaş
Did you ever identify an appropriate replacement port?
Lepec - Yanıt Paylaş
something was broken out of the port of the USB connection
MoreZemtor - Yanıt Paylaş
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 8,782
