Ana içeriğe geç
Asus A53S Optical Drive Replacement
Neye ihtiyacın var
  1. Asus A53S Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 1. Asus A53S Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 2. Asus A53S Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 3.
    • Power off your device and remove the battery before beginning this guide.
    • Open the laptop.
    • Using the Spudger, insert the flat end into the notches at the top of the keyboard and slowly "pop" the keyboard up and out of the device.
  2. Asus A53S Optical Drive Replacement: adım 2, 2 resimden 1. Asus A53S Optical Drive Replacement: adım 2, 2 resimden 2.
    • Using the flat end of the spudger, lift the black lock bard on the ZIF connector and disconnect the keyboard from the computer.
    • Remove the keyboard.
  3. Asus A53S Optical Drive Replacement: adım 3, 2 resimden 1. Asus A53S Optical Drive Replacement: adım 3, 2 resimden 2.
    • Remove the single 6 mm screw using the Phillips #1 screwdriver.
  4. Asus A53S Optical Drive Replacement: adım 4, 1 resimden 1.
    • Pull out the optical drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 163
