Ana içeriğe geç
Asus A53S Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 1. Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 2. Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 3.
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws at the indicated places.
    • Remove the back plate.
  2. Asus A53S Wi-Fi Card Replacement: adım 2, 2 resimden 1. Asus A53S Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Place a spudger under the white wire and pull it up gently, disconnecting it from the Wi-FI card.
    • Use the same method on the black wire.
  3. Asus A53S Wi-Fi Card Replacement: adım 3, 3 resimden 1. Asus A53S Wi-Fi Card Replacement: adım 3, 3 resimden 2. Asus A53S Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screw where indicated, allowing the Wi-Fi card to pop up.
    • Remove the Wi-Fi card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Laurie Medina
638 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 491
