Ana içeriğe geç
Asus CM1745 CPU Replacement
Neye ihtiyacın var
  1. Asus CM1745 CPU Replacement, Heatsink: adım 1, 2 resimden 1. Asus CM1745 CPU Replacement, Heatsink: adım 1, 2 resimden 2.
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
    FixBot'a Sor
    Yorum Ekle
  2. Asus CM1745 CPU Replacement: adım 2, 2 resimden 1. Asus CM1745 CPU Replacement: adım 2, 2 resimden 2.
    • Unplug the CPU fan connector from the motherboard.
    • Then open the latch under the CPU fan and unhook the metal fasteners.
    • Lift the CPU heatsink and cable off of the CPU carefully.
    FixBot'a Sor
    Yorum Ekle
  3. Asus CM1745 CPU Replacement: adım 3, 3 resimden 1. Asus CM1745 CPU Replacement: adım 3, 3 resimden 2. Asus CM1745 CPU Replacement: adım 3, 3 resimden 3.
    • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
    • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
    • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
    • Replug the CPU Fan connector to the motherboard header.
    • Check out the How to Apply Thermal Paste guide for more details and best practices.
    FixBot'a Sor
    Yorum Ekle
  4. Asus CM1745 CPU Replacement, CPU: adım 4, 3 resimden 1. Asus CM1745 CPU Replacement, CPU: adım 4, 3 resimden 2. Asus CM1745 CPU Replacement, CPU: adım 4, 3 resimden 3.
    • Remove CPU Heatsink to expose CPU.
    • Open the silver retention bar of the CPU by pulling the bar out of the plastic hook and hinging it open.
    • Remembering the orientation of the CPU, carefully pull the CPU out of the socket.
    FixBot'a Sor
    Yorum Ekle
  5. Asus CM1745 CPU Replacement: adım 5, 3 resimden 1. Asus CM1745 CPU Replacement: adım 5, 3 resimden 2. Asus CM1745 CPU Replacement: adım 5, 3 resimden 3.
    • Take your replacement CPU and line up the arrows marked in the photos.
    • Place the CPU in the socket and gently massage the top of the cpu to ensure that there is no wiggle.
    • If the CPU feels secure, pull the retention bar back into place.
    • Place new thermal paste onto the CPU and replace the heatsink.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If everything looks correct, boot the computer up. It may take a few minutes to fully boot as the motherboard recognizes the new hardware.
7 farklı kişi bu kılavuzu tamamladı.
TC Fowlar
896 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 112
Her zaman: 2,823
