Ana içeriğe geç
Asus CM1745 Heatsink Replacement
Neye ihtiyacın var
  1. Asus CM1745 Heatsink Replacement, Heatsink: adım 1, 2 resimden 1. Asus CM1745 Heatsink Replacement, Heatsink: adım 1, 2 resimden 2.
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
    FixBot'a Sor
    Yorum Ekle
  2. Asus CM1745 Heatsink Replacement: adım 2, 2 resimden 1. Asus CM1745 Heatsink Replacement: adım 2, 2 resimden 2.
    • Unplug the CPU fan connector from the motherboard.
    • Then open the latch under the CPU fan and unhook the metal fasteners.
    • Lift the CPU heatsink and cable off of the CPU carefully.
    FixBot'a Sor
    Yorum Ekle
  3. Asus CM1745 Heatsink Replacement: adım 3, 3 resimden 1. Asus CM1745 Heatsink Replacement: adım 3, 3 resimden 2. Asus CM1745 Heatsink Replacement: adım 3, 3 resimden 3.
    • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
    • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
    • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
    • Replug the CPU Fan connector to the motherboard header.
    • Check out the How to Apply Thermal Paste guide for more details and best practices.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Replug the computer and turn it on. If the fan spins, reattach the sidepanels and the replacement is complete.
TC Fowlar
896 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 1,396
