Ana içeriğe geç
Asus Chromebook C300MA-BBCLN12 Motherboard Replacement
Brooke Austin
Brooke Austin ve 6 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
This guide will show you how to open the casing on your Chromebook and remove your motherboard so that you can replace it.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 2, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 2, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 2, 3 resimden 3.
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 5, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the bottom housing.
  7. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Remove the two 6.0mm Phillips #00 screws that secure the metal heat shield to the motherboard.
    • Remove the metal heat shield.
  8. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 8, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 8, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 8, 3 resimden 3.
    • Peel back the protective tape that covers the display cable connector.
    • Disconnect the display cable from the motherboard using the plastic spudger tool.
  9. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 9, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 9, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the speaker cable from the motherboard using the plastic spudger tool.
  10. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 10, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 10, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 10, 3 resimden 3.
    • Flip back the hinge that secures the blue daughterboard cable to the motherboard using the tweezers.
    • Disconnect the blue cable connecting the motherboard to the daughterboard by pulling on the blue cable tab.
  11. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 11, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the four 3.0mm Phillips #00 screws that attach the left hinge.
    • Remove the large silver 5.0mm Phillips #00 screw from the center-left side of the motherboard.
  12. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 12, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the three 3.0mm Phillips #00 screws that secure the motherboard to the housing.
  13. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Brooke Austin
419 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 851
