Ana içeriğe geç
Asus Chromebook Flip C302CA Motherboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook Flip C302CA Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 2, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 2, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Motherboard Replacement: adım 3, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 3, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Motherboard Replacement: adım 4, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Motherboard Replacement, Battery: adım 5, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement, Battery: adım 5, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement, Battery: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Motherboard Replacement: adım 6, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Motherboard Replacement: adım 7, 1 resimden 1.
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Motherboard Replacement, Wi-Fi Card: adım 8, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement, Wi-Fi Card: adım 8, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement, Wi-Fi Card: adım 8, 3 resimden 3.
    • Carefully remove the black and white cables connected to the Wi-Fi card.
    • Remove the single 2 mm screw while holding the Wi-Fi card using the Phillips #00 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  9. Asus Chromebook Flip C302CA Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
    • Lift the four tabs connected to the motherboard using tweezers.
  10. Asus Chromebook Flip C302CA Motherboard Replacement: adım 10, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 10, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 10, 3 resimden 3.
    • Carefully pull out the tabs connected to the motherboard.
  11. Asus Chromebook Flip C302CA Motherboard Replacement: adım 11, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the speaker cable connected to the motherboard with tweezers.
    • Careful not to damage your cable.
  12. Asus Chromebook Flip C302CA Motherboard Replacement: adım 12, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 12, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the ribbon cable from the motherboard.
    • Then, remove the two 1mm screws with a PH00 screwdriver.
  13. Asus Chromebook Flip C302CA Motherboard Replacement: adım 13, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 13, 2 resimden 2.
    • Lift and remove the copper from the right side of the motherboard.
  14. Asus Chromebook Flip C302CA Motherboard Replacement: adım 14, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the four 2mm screws with a PH00 screwdriver.
  15. Asus Chromebook Flip C302CA Motherboard Replacement: adım 15, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the six 1mm Screws with a PH00 screwdriver.
  16. Asus Chromebook Flip C302CA Motherboard Replacement: adım 16, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 16, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 16, 3 resimden 3.
    • Remove the two pictured tabs with a nylon spudger.
  17. Asus Chromebook Flip C302CA Motherboard Replacement: adım 17, 3 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 17, 3 resimden 2. Asus Chromebook Flip C302CA Motherboard Replacement: adım 17, 3 resimden 3.
    • Lift the tab with a small pick that connects to the ribbon cable
  18. Asus Chromebook Flip C302CA Motherboard Replacement: adım 18, 2 resimden 1. Asus Chromebook Flip C302CA Motherboard Replacement: adım 18, 2 resimden 2.
    • Remove the mother from the left side of the computer
Sonuç
Bir başkası bu kılavuzu tamamladı.
Asifiwe Murhula
259 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Saknee Spring 2022 Gateway, Team 1-2, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G2
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for this very useful guide. We were able to replace the motherboard and put it back together, but the device only runs while plugged in. We double checked all of the connections. How can I check to see if the battery itself is dead? Or maybe there are other ideas to try? Much appreciated.
Wildcat Python - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 731
