Giriş
The fan blows hot air out of the laptop and takes in cool air. Be sure to have a compatible fan for this laptop when you replace it.
Neye ihtiyacın var
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
Remove the three 2.0mm Phillips #1 screws that secure the metal guard.
With the screws removed, simply lift the metal guard out of the laptop to remove it.
