Ana içeriğe geç
Asus G75VW-BHI7N07 USB Port Replacement
Neye ihtiyacın var
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: adım 1, 3 resimden 1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: adım 1, 3 resimden 2. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: adım 1, 3 resimden 3.
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: adım 2, 3 resimden 1. Asus G75VW-BHI7N07 USB Port Replacement: adım 2, 3 resimden 2. Asus G75VW-BHI7N07 USB Port Replacement: adım 2, 3 resimden 3.
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: adım 3, 2 resimden 1. Asus G75VW-BHI7N07 USB Port Replacement: adım 3, 2 resimden 2.
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: adım 4, 2 resimden 1. Asus G75VW-BHI7N07 USB Port Replacement: adım 4, 2 resimden 2.
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: adım 5, 3 resimden 1. Asus G75VW-BHI7N07 USB Port Replacement: adım 5, 3 resimden 2. Asus G75VW-BHI7N07 USB Port Replacement: adım 5, 3 resimden 3.
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: adım 7, 1 resimden 1.
    • Carefully lift the motherboard up using the opening tool.
    • You should be able to see the USB port.
    • Now you will be able to desolder the faulty USB port.
    • Here is a link on desoldering How To Solder and Desolder Connections
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joy
437 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 593
