Ana içeriğe geç
Asus K55a-si50301p Battery Replacement
  1. Asus K55a-si50301p Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Battery Replacement: adım 2, 1 resimden 1.
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Battery Replacement: adım 3, 1 resimden 1.
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 692
