Ana içeriğe geç
Asus K55a-si50301p USB 3.0 Replacement
Neye ihtiyacın var
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: adım 1, 1 resimden 1.
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: adım 2, 1 resimden 1.
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: adım 3, 1 resimden 1.
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: adım 4, 1 resimden 1.
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: adım 5, 1 resimden 1.
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: adım 6, 2 resimden 1. Asus K55a-si50301p USB 3.0 Replacement: adım 6, 2 resimden 2.
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: adım 7, 1 resimden 1.
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: adım 8, 1 resimden 1.
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: adım 9, 1 resimden 1.
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
after doing this start button lights up but will not boot
David Garside - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 682
