Ana içeriğe geç
Asus MeMO Pad 7 ME170C Ribbon Cable Replacement
Tatiana Schneider
Tatiana Schneider ve 8 diğer katkıda bulunanlar
En son February 24, 2025 tarihinde güncellendi
20 - 30 dakika
Orta
Madde imleri!
Daha İyi Resimler Gerekli
Dilim ve Zar
Daha iyi giriş
Öğrenci İş Başında
The ribbon cable acts as a bundling unit to hold multiple wires together. Basically, instead of having a bunch of cords in random places, the ribbon holds them together as one, clean unit.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: adım 1, 3 resimden 3.
    • Before beginning to disassemble, power off the device.
    • Be gentle with the screen of the device. Excessive force can damage it.
    • Using the Jimmy tool, pry it into the seam of the device.
    • With the Jimmy tool, pry open the device through the seam.
  2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 2, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 2, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 2, 3 resimden 3.
    • Locate the black bundle cable connector attached to the battery.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Use the blue plastic opening tool to loosen the black bundle cable connector Loosen it in a back and forth motion towards the battery.
  3. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 3, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 3, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to loosen the battery by using the edges.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 4, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 4, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the wide nosed tweezers to remove the yellow tape that secures the bottom end of the ribbon cable. Gently lift the edge of the tape.
  5. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 5, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 5, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 5, 3 resimden 3.
    • Using wide nosed tweezers, pinch the blue tab attached to the ribbon cable towards the top of the device that is inserted in the mother board.
    • Pull the ribbon cable firmly. However, do not rip it out.
    • In a lateral motion, pull the blue tab gently.
    • At the bottom of the device, use wide nosed tweezers to pinch the opposite blue tab of the ribbon cable.
  6. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 6, 3 resimden 1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 6, 3 resimden 2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: adım 6, 3 resimden 3.
    • The middle of the ribbon will be glued down to the device.
    • Heat the iOpener in the microwave for one minute.
    • After heating, vertically place the iOpener on top of the ribbon cable. Let it sit for one minute.
    • Remove the iOpener.
    • Use the wide nosed tweezers to pinch the ribbon cable from the middle. Pull it up firmly to detach. Be careful not to rip it off.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,111
