Neye ihtiyacın var
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
Disconnect the Wifi/Bluetooth RF cables from the wireless card.
Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
Pull straight up to disconnect the SATA combo cable from the motherboard.
Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
Four 3.7 mm screws
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
