Ana içeriğe geç
Asus Q551L Repair Motherboard Replacement
Neye ihtiyacın var
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q551L Repair Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: adım 3, 2 resimden 1. Asus Q551L Repair Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: adım 4, 2 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 4, 2 resimden 2.
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
    In addition to instructions here, the manufacturer instructed to boot computer once battery is removed boot up using ac power. This might only apply to Macs. Power down and install battery. Let the battery drain. Shut down. Then charge the computer for12 hours to fully activate the lithium ion to reach full capacit. Also drain battery at least three times to reach maximum capacity.
    Tindara Certo - Yanıt
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 1. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 2. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 3.
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: adım 7, 2 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 7, 2 resimden 2.
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 2. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,524
