Giriş
The Asus ROG G20CB is a compact gaming desktop that uses custom cooling and a specialized case layout. Replacing the graphics card (GPU) can significantly boost performance, but due to the small form factor and custom internal design, it's slightly trickier than on a regular tower. This guide will walk you through the process carefully.
Check GPU size: The G20CB supports small dual-slot GPUs (generally under 10.5 inches / 266mm long). Only 6-pin or 8-pin PCIe connectors.
Neye ihtiyacın var
Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
Remove the three 4.6 mm Phillips screws from the graphics card housing.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
