Giriş
Use this guide to remove or replace the optical drive in an Asus ROG G751JL.
Neye ihtiyacın var
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the 5.2 mm Phillips #00 screw securing the optical drive.
Bir başkası bu kılavuzu tamamladı.
