Giriş
This guide will teach the user how to safely access the RAM sticks without damaging them or the surrounding components.
Neye ihtiyacın var
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the 5.2 mm Phillips #00 screw securing the optical drive.
Use the point of a spudger to pry out eleven rubber plugs covering the screws on the bottom of the laptop.
Flip the laptop right-side up.
Use an opening pick to pry the left and right edges of the battery cover away from the laptop enough that you can grip the cover with your fingers.
Pull the speaker connectors straight away from each other to disconnect the speaker cable.
Open the laptop's display to a 90° angle.
Use a spudger to pry against one of the screw tabs on the back of the upper case assembly.
Repeat this procedure with the other tab.
Use the tip of a spudger to flip up the small locking flap of the keyboard backlight cable ZIF connector.
Gently pull the cable out of its socket.
Pull the battery cable away from the connector in the same direction as the individual wires are running to disconnect the battery.
