Giriş
The motherboard of the device is the tablet's main processing unit. To reach it, the plastic backing, battery, and camera must be removed.
Neye ihtiyacın var
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Insert the opening tool into the seam of the tablet casing and gently pry upwards.
With a little force, you will feel the clips release.
This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
The camera board is located in the red square in this image.
Lift up the power button cable retention clip on the motherboard and pull the cable out.
These "Connection Apparatuses" are ZIF (Zero Insertion Force) FFC (Flexible Flat Cable) Connectors, and instead of trying to pull/wiggle the ribbon cable out, the side of the Connector with the ribbon going into it, has a gate that will flip up making the ribbon just simply slide out. The ribbons are also easier to reinstall with the gates flipped up as well. You just have to be careful with the gates as to not break the hinges. I will typically use the plastic case opening tool to pry the gate open.
Gently pull the Orange ribbon cable out of the connection port.
This port DOES have a clip. It's the white bit on the backside of the port. Flip it up and the connector will slide loose with no force at all.
Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
My Asus Transformer is a T100TAF which doesn't have the yellow tape over the battery connector and the plug attached to the battery appears to be firmly fitted into the socket mounted on the Main Board. I have yet to work out how to remove the plug but the photo nearest above is a help as it shows the little spigot attached to the plug and which fits into the notch in the socket is in fact part of the plug. Back to the work bench.
The battery plug was simply a very tight fit in the socket. My problem was the tablet not turning off properly when we wished. It would appear to switch off but was drawing about 250 mA from the battery which flattened it in a day or so. Unplugging the battery, waiting for a minute or so and re-connecting it solved the problem at least so far.
At the top end of the motherboard, use tweezers to gently slide the orange connection apparatus out of the connection port.
Using the tweezers, gently remove the LCD connection apparatus from the LCD connection port.
18 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
As the previous comment stated (but only for step 7), ALL the connection apparatus have a white "flip" side (for STEP 7, 9, 17 and 19). Instead of struggling (like I did first), simply lift up the white side with your nail and gently remove the ribbons. Also, it is not necessary to entirely remove the battery (STEP 13) to carefully disconnect the cables. Thanks for for the tutorial though!
Hey! I have the T100TA. Super happy with it, but it's a bit older and only has 1gb of RAM. Is it possible to put the board of the T100(which has 2gb of RAM) into it? I assume size is the same, but are the connections? Thanks!
I have “downgraded” my T100TAM by installing a motherboard from the T100 (because I couldn’t find a T100TAM motherboard). So the other way around should also be possible.
I replaced the motherboard. Did everthing right. But it didn't turned on.
Is there any way to start up the motherboard first time?
Where is the hard drive located on these? Is it on the board and can it be swapped out? I have data on one which is locked and the device won’t boot to anything at all so stuck!
the problem of my t101ha is sdg smd in motherboard i cannot recall the value .. plsss help me
Thanks for the tutorial! I did not realize there is a tool for opening gadgets. I almost always break a few plastic clips. By replacing the motherboard of Asus T100 tablets is there a compatibility list I can use to buy a replacement? I have a T100TA-DK046H (~500$) from 2014, which has possibly motherboard issues (it does not recognize TPM and turns off randomly after showing some screen artifacts). It has a 90NB0451-R00100 motherboard. I got a quotation from a company for a new motherboard and repair, but it is a lot more than I expected (~300$) and I can see much cheaper (<100$) Asus motherboards on amazon and ebay e.g. 60NB0450-MB1012. I think I would rather buy something like that if it is compatible with the touch screen and other periferials and fix it myself…
I think all T100* mobo is compatible with all T100* periferials. At least that is my impression from post, comments and the reply of the Asus service.
what is wifi model?
Please note the T100TAF BING model has a different motherboard and no left speaker
I replaced the screen, damaged the original motherboard, then replaced it with a new motherboard. Unfortunately, now it wont start. The power LED blinks 5 times white when I press the power button.
Is it because the new motherboard does not have the proper BIOS (or something like that) installed? Or does the blinking means that there is still a damaged hardware component ?
Thanks
My t100 got destroyed, I removed the mother board with the built in storage. I need to access the storage to recover files. Is this possible?
