Ana içeriğe geç
Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 1 resimden 1.
    • Remove the 11 Philips #00 screws from the underside of the device.
    • Four 12mm screws.
    • Three 10mm screws.
    • Four 7mm screws.
  2. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • With the laptop open, use a opening tool to detach the keyboard from the laptops body. Lift the keyboard up slowly as to not damage the ribbon cables that connect from the keyboard.
  3. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 3, 2 resimden 1. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Carefully pull out the three ribbon connectors at the front of the device.
    • After the three small cables are disconnected, the keyboard can be lifted up more to allow for easier access to the larger fourth ribbon cable.
  4. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Just below the fan is the wi-fi card. Disconnect the black and white antenna wires by applying a gentle upward force.
  5. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Remove the 3mm Phillips #00 screw securing the card in place.
  6. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Gently pull the card to the side and it will come out of its socket. The wi-fi card can now be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 1,539
