Ana içeriğe geç
Asus X401A Processor Replacement
Tyler Stiles
Tyler Stiles ve 2 diğer katkıda bulunanlar
En son March 7, 2024 tarihinde güncellendi
45 dakika - 1 saat
Orta
This guide will teach you how to take apart your laptop in order to get to the processor, fan, graphics card, and many other important components. Through the steps listed below, you will be able to identify and replace your laptop's processor!
Neye ihtiyacın var
  1. Asus X401A Processor Replacement, Processor: adım 1, 2 resimden 1. Asus X401A Processor Replacement, Processor: adım 1, 2 resimden 2.
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: adım 2, 3 resimden 1. Asus X401A Processor Replacement: adım 2, 3 resimden 2. Asus X401A Processor Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: adım 3, 3 resimden 1. Asus X401A Processor Replacement: adım 3, 3 resimden 2. Asus X401A Processor Replacement: adım 3, 3 resimden 3.
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: adım 4, 3 resimden 1. Asus X401A Processor Replacement: adım 4, 3 resimden 2. Asus X401A Processor Replacement: adım 4, 3 resimden 3.
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: adım 5, 1 resimden 1.
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: adım 6, 1 resimden 1.
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: adım 7, 2 resimden 1. Asus X401A Processor Replacement: adım 7, 2 resimden 2.
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: adım 8, 1 resimden 1.
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: adım 9, 3 resimden 1. Asus X401A Processor Replacement: adım 9, 3 resimden 2. Asus X401A Processor Replacement: adım 9, 3 resimden 3.
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: adım 10, 2 resimden 1. Asus X401A Processor Replacement: adım 10, 2 resimden 2.
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: adım 11, 2 resimden 1. Asus X401A Processor Replacement: adım 11, 2 resimden 2.
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: adım 12, 3 resimden 1. Asus X401A Processor Replacement: adım 12, 3 resimden 2. Asus X401A Processor Replacement: adım 12, 3 resimden 3.
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Stiles
152 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G4
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 1,945
