Ana içeriğe geç
Asus X553MA-BPD07051 Motherboard Replacement
Neye ihtiyacın var
  1. Asus X553MA-BPD07051 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Motherboard Replacement: adım 3, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Motherboard Replacement: adım 5, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Motherboard Replacement: adım 6, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 6, 2 resimden 2.
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 Motherboard Replacement, Hard Drive: adım 7, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
  8. Asus X553MA-BPD07051 Motherboard Replacement: adım 8, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
  9. Asus X553MA-BPD07051 Motherboard Replacement, Optical Drive: adım 9, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement, Optical Drive: adım 9, 2 resimden 2.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
  10. Asus X553MA-BPD07051 Motherboard Replacement: adım 10, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 10, 2 resimden 2.
    • Gently slide the optical drive out from the motherboard.
  11. Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
  12. Asus X553MA-BPD07051 Motherboard Replacement: adım 12, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 12, 2 resimden 2.
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
  13. Asus X553MA-BPD07051 Motherboard Replacement: adım 13, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 13, 2 resimden 2.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
  14. Asus X553MA-BPD07051 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the tape from the motherboard.
  15. Asus X553MA-BPD07051 Motherboard Replacement: adım 15, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 15, 2 resimden 2.
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
  16. Asus X553MA-BPD07051 Motherboard Replacement: adım 16, 2 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 16, 2 resimden 2.
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
  17. Asus X553MA-BPD07051 Motherboard Replacement: adım 17, 3 resimden 1. Asus X553MA-BPD07051 Motherboard Replacement: adım 17, 3 resimden 2. Asus X553MA-BPD07051 Motherboard Replacement: adım 17, 3 resimden 3.
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephanie DeCarvalho
898 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 UMass Dartmouth, Team S1-G4, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G4
3 Üyeler
5 Yorum
Hi! Where the !&&* is the CMOS battery?
butch zvonko - Yanıt
Hi, I’m sorry but I don’t have an image of the CMOS battery! It should be located on the motherboard though.
Stephanie DeCarvalho -
See my reply below. There isn’t one.
Gazza
gazza667 -
Hi, I think there is no CMOS battery on this motherboard. See https://vinafix.com/media/asus-x553ma.11....
I can vouch that there is NO CMOS battery on this laptop. I now own one from a friend who had it condemned by another ‘repair tech’. It turned out that the display connector was not secured properly. Anyway, having stripped it down completely, i decided to replace the CMOS battery before putting it back together & there isn’t one. On the underside of the board is an area with white plastic in the shape of a button battery. On reassembly i noticed the CMOS had lost the clock memory. Which i put down to disconnecting the battery. It must be powered when the battery is connected & not separately.
Gazza
gazza667 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 2,365
