Giriş
This guide will show you how to replace the fan in an Asus ZenBook UX303U laptop.
Neye ihtiyacın var
Remove the eleven 4 mm Phillips #00 screws from the back panel.
These screws on other models are Torx T5 or T6, not Phillips
T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
Agree. Same as my laptop.
Moops -
Using a plastic opening tool pry the back panel off of the laptop.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
Remove the speakers from the old battery.
This was a bit more fiddly than expected given the speaker arms are stuck to the battery
Yes, it was taped on their quite strongly. I just tried to make sure the tape stayed stuck to the speakers and not the battery.
Moops -
Disconnect the display cable from the motherboard with a plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
Jon Kerridge - Yanıt
