Ana içeriğe geç
Asus ZenFone 3 Zoom Screen Replacement
Neye ihtiyacın var
  1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: adım 1, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: adım 1, 2 resimden 2.
    • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. Asus ZenFone 3 Zoom Screen Replacement: adım 2, 1 resimden 1.
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. Asus ZenFone 3 Zoom Screen Replacement: adım 3, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 3, 2 resimden 2.
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. Asus ZenFone 3 Zoom Screen Replacement: adım 4, 1 resimden 1.
    • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
  5. Asus ZenFone 3 Zoom Screen Replacement: adım 5, 1 resimden 1.
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. Asus ZenFone 3 Zoom Screen Replacement: adım 6, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 6, 2 resimden 2.
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. Asus ZenFone 3 Zoom Screen Replacement: adım 7, 1 resimden 1.
    • De-solder the single black speaker wire attached on the left side of the phone.
  8. Asus ZenFone 3 Zoom Screen Replacement: adım 8, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 8, 2 resimden 2.
    • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
  9. Asus ZenFone 3 Zoom Screen Replacement: adım 9, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
  10. Asus ZenFone 3 Zoom Screen Replacement: adım 10, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 10, 2 resimden 2.
    • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
  11. Asus ZenFone 3 Zoom Screen Replacement: adım 11, 1 resimden 1.
    • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
  12. Asus ZenFone 3 Zoom Screen Replacement: adım 12, 1 resimden 1.
    • Remove the speaker once exposed.
  13. Asus ZenFone 3 Zoom Screen Replacement: adım 13, 1 resimden 1.
    • Use iOpener to soften the adhesive keeping the screen on the device.
  14. Asus ZenFone 3 Zoom Screen Replacement: adım 14, 1 resimden 1.
    • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
  15. Asus ZenFone 3 Zoom Screen Replacement: adım 15, 1 resimden 1.
    • Progress around the perimeter of the phone with the pry tool till the screen is off.
  16. Asus ZenFone 3 Zoom Screen Replacement: adım 16, 2 resimden 1. Asus ZenFone 3 Zoom Screen Replacement: adım 16, 2 resimden 2.
    • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
  17. Asus ZenFone 3 Zoom Screen Replacement: adım 17, 1 resimden 1.
    • The finished product will be a screen with nothing attached to the body of the phone.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Luke Theiss
271 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 28
Her zaman: 2,441
