Ana içeriğe geç
Asus ZenFone 5 Battery Replacement
Neye ihtiyacın var
  1. Asus ZenFone 5 Battery Replacement, Battery: adım 1, 3 resimden 1. Asus ZenFone 5 Battery Replacement, Battery: adım 1, 3 resimden 2. Asus ZenFone 5 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Battery Replacement: adım 2, 3 resimden 1. Asus ZenFone 5 Battery Replacement: adım 2, 3 resimden 2. Asus ZenFone 5 Battery Replacement: adım 2, 3 resimden 3.
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Battery Replacement: adım 3, 3 resimden 1. Asus ZenFone 5 Battery Replacement: adım 3, 3 resimden 2. Asus ZenFone 5 Battery Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Battery Replacement: adım 4, 3 resimden 1. Asus ZenFone 5 Battery Replacement: adım 4, 3 resimden 2. Asus ZenFone 5 Battery Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to release the red square that is holding the bottom assembly piece from the frame.
    • Using a Phillips #00 screwdriver, remove the five screws from the bottom midframe.
    • Gently remove the bottom midframe.
  5. Asus ZenFone 5 Battery Replacement: adım 5, 2 resimden 1. Asus ZenFone 5 Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
    Thanks a lot for this Guide, it looks great and full of details!
    I should replace my Zenfone 5 battery, where should i get i new one?
    Thanks Again
    Francesco
    Francesco Campana - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Wait, Asus Zenfone 5 (ZE620KL, ZF620KL) has only 3300 mAh battery capacity. Why in the image above the battery label say it's 4000 mAh?
Jufans Anurwan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 66
Her zaman: 5,182
