Ana içeriğe geç
Asus Zenbook UX303L Battery Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX303L Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your device is OFF before performing this procedure.
    • Remove the eight 3 mm long screws using a T5 Torx Screwdriver.
    • Remove the single 8 mm long screw using a T5 Torx screwdriver.
  2. Asus Zenbook UX303L Battery Replacement: adım 2, 2 resimden 1. Asus Zenbook UX303L Battery Replacement: adım 2, 2 resimden 2.
    • Lift and remove the back cover.
    • If your case does not easily come free, you may need to remove screws under the plastic feet on the bottom case.
  3. Asus Zenbook UX303L Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws from the sides of the battery.
    • Use a Phillips #0 screwdriver to remove the single 6 mm screw in the center of the battery.
  4. Asus Zenbook UX303L Battery Replacement: adım 4, 2 resimden 1. Asus Zenbook UX303L Battery Replacement: adım 4, 2 resimden 2.
    • Lift the battery connector up out of its socket on the motherboard to disconnect it.
    • A plastic opening tool can help lift the connector out of its socket. Do not pry on the socket itself or you risk damaging the motherboard.
  5. Asus Zenbook UX303L Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the speaker by carefully pulling the speaker cable away from its socket on the motherboard.
  6. Asus Zenbook UX303L Battery Replacement: adım 6, 1 resimden 1.
    • Deroute the speaker cable from the clips so the battery can be fully removed.
  7. Asus Zenbook UX303L Battery Replacement: adım 7, 2 resimden 1. Asus Zenbook UX303L Battery Replacement: adım 7, 2 resimden 2.
    • Lift up and remove the battery and speakers from the device.
  8. Asus Zenbook UX303L Battery Replacement: adım 8, 1 resimden 1.
    • Remove the speakers from the old battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aashray Nagpal
163 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 239
Her zaman: 11,999
