Ana içeriğe geç
Atari Lynx Battery Wire Replacement
Neye ihtiyacın var
  1. Atari Lynx Battery Wire Replacement, Atari Lynx: adım 1, 1 resimden 1.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Battery Wire Replacement: adım 2, 1 resimden 1.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Battery Wire Replacement: adım 3, 1 resimden 1.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Battery Wire Replacement: adım 4, 1 resimden 1.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Battery Wire Replacement, Battery Wires: adım 5, 1 resimden 1.
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  6. Atari Lynx Battery Wire Replacement: adım 6, 1 resimden 1.
    • Desolder the black wire as shown.
  7. Atari Lynx Battery Wire Replacement: adım 7, 2 resimden 1. Atari Lynx Battery Wire Replacement: adım 7, 2 resimden 2.
    • Desolder the white wire and then the red wire as shown.
  8. Atari Lynx Battery Wire Replacement: adım 8, 1 resimden 1.
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
Sonuç
John Lopez
443 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G42
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 1,786
