Giriş
If you are having problems with your turn table not spinning and have not found the cause to be a problem with the power or wiring, you may have a faulty Regulator on your board that is preventing power from reaching the motor.
Neye ihtiyacın var
Use a Phillips #2 screwdriver to remove the four 2.5 mm screws.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
