Ana içeriğe geç
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
Neye ihtiyacın var
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: adım 1, 2 resimden 1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: adım 1, 2 resimden 2.
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 2, 2 resimden 1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 2, 2 resimden 2.
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 3, 1 resimden 1.
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 4, 2 resimden 1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 4, 2 resimden 2.
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 5, 1 resimden 1.
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 6, 3 resimden 1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 6, 3 resimden 2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 6, 3 resimden 3.
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 7, 1 resimden 1.
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 8, 1 resimden 1.
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 9, 1 resimden 1.
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 10, 3 resimden 1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 10, 3 resimden 2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: adım 10, 3 resimden 3.
    • Test the function by spinning the platter and put the rubber mat into place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zonghao Li
235 İtibar
1 Kılavuz yazıldı
2 Yorum
Thank you so much!
Joe - Yanıt
Ditto that! Thanks for the clear directions.
Steph - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 38
Son 7 gün: 220
Son 30 gün: 888
Her zaman: 18,551
