Ana içeriğe geç
Audio-Technica LP60XBT Turntable Gear Replacement
Devon Ferreira
Devon Ferreira ve 2 diğer katkıda bulunanlar
En son January 6, 2025 tarihinde güncellendi
10 - 15 dakika
Orta
At times, the gear that rotates in the Audio-Technica LP60XBT turntable can become old and worn causing it to break. The replacement of the gear is relatively fast and simple and can save the user a lot of money by not buying a new turntable. A successful replacement of the gear can eliminate waste in landfills; when discarded in landfills, record players can leak chemicals that are toxic to humans.
Neye ihtiyacın var
Aletler
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: adım 1, 2 resimden 1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: adım 1, 2 resimden 2.
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: adım 2, 1 resimden 1.
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: adım 3, 2 resimden 1. Audio-Technica LP60XBT Turntable Gear Replacement: adım 3, 2 resimden 2.
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: adım 4, 1 resimden 1.
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: adım 5, 3 resimden 1. Audio-Technica LP60XBT Turntable Gear Replacement: adım 5, 3 resimden 2. Audio-Technica LP60XBT Turntable Gear Replacement: adım 5, 3 resimden 3.
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: adım 6, 1 resimden 1.
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
Sonuç
Devon Ferreira
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,736
