Ana içeriğe geç
Auking M8-F PCB Button Panel Replacement
Neye ihtiyacın var
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: adım 1, 2 resimden 1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: adım 1, 2 resimden 2.
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Auking M8-F PCB Button Panel Replacement: adım 2, 2 resimden 1. Auking M8-F PCB Button Panel Replacement: adım 2, 2 resimden 2.
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
    FixBot'a Sor
    Yorum Ekle
  3. Auking M8-F PCB Button Panel Replacement: adım 3, 2 resimden 1. Auking M8-F PCB Button Panel Replacement: adım 3, 2 resimden 2.
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
    FixBot'a Sor
    Yorum Ekle
  4. Auking M8-F PCB Button Panel Replacement: adım 4, 3 resimden 1. Auking M8-F PCB Button Panel Replacement: adım 4, 3 resimden 2. Auking M8-F PCB Button Panel Replacement: adım 4, 3 resimden 3.
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aubrey Haynes
286 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 324
