  1. 1. Check the website for that node to make sure node has sent a reading in the last hour. Node that website currently goes to ECORSE, enter the correct site ID in the hyperlink.
    • 1. Check the website for that node to make sure node has sent a reading in the last hour.
    • Node that website currently goes to ECORSE, enter the correct site ID in the hyperlink.
    • 2. Contact the Real-Time Water Systems Lab to update the sampling frequency to every 5 minutes to make testing easier.
  2. 3. Disconnect the plug to the solar panel (yellow circle). Then, grabbing the green connector, pull the battery connector from the solar charge controller (blue arrow). 4. Disconnect the plugs for the autosampler battery.
    • 3. Disconnect the plug to the solar panel (yellow circle).
    • Then, grabbing the green connector, pull the battery connector from the solar charge controller (blue arrow).
    • 4. Disconnect the plugs for the autosampler battery.
    • 5. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!.
  3. 6. Confirm the autosampler is configured correctly. See this tutorial for more details.
    • 6. Confirm the autosampler is configured correctly. See this tutorial for more details.
    • Confirm the autosampler is programming correctly. See this tutorialfor more details.
  4. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  5. Now we will trigger a sample from the autosampler to confirm the sampling works.
    • Now we will trigger a sample from the autosampler to confirm the sampling works.
    • 7. Press the "MANUAL SAMPLE" button and then "ENTER/PROGRAM".
    • Confirm the autosampler stars.
  6. 8. Confirm there are no breaks in the wiring between the interface board the autosampler. See this tutorial for more details.
    • 8. Confirm there are no breaks in the wiring between the interface board the autosampler. See this tutorial for more details.
  7. Click here to  watch a video of how to trigger the autosampler with the node battery. 9. Make sure the jumper is on so that the LEDs will light up during the test. 10. Plug the red and black jumper wires into the node battery terminal plug. This should turn on the yellow LED.
    • Click here to watch a video of how to trigger the autosampler with the node battery.
    • 9. Make sure the jumper is on so that the LEDs will light up during the test.
    • 10. Plug the red and black jumper wires into the node battery terminal plug. This should turn on the yellow LED.
    • 11. Touch the white jumper wire to the red wire then the white wire until the bottle count goes to zero. The blue LED will light up after each connection.
    • The autosampler will then trigger the sampling. The green LED will blink the number of bottles it is on. The red LED will stay on until the sampling is complete.
  8. If everything else works, then there is an issue with the code/node. Contact the Real-Time Water Systems Lab for further instructions.
    • If everything else works, then there is an issue with the code/node. Contact the Real-Time Water Systems Lab for further instructions.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brooke Mason
2.289 Reputation
15 adet Kılavuz yazıldı
Open-Storm Open-Storm üyesi
Community
13 Üyeler
19 adet Kılavuz yazıldı
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 36
