Ana içeriğe geç
Axess SPBT1031 Auxiliary Port Replacement
Neye ihtiyacın var
  1. Axess SPBT1031 Auxiliary Port Replacement, Red Interface Plate: adım 1, 1 resimden 1.
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
    FixBot'a Sor
    Yorum Ekle
  2. Axess SPBT1031 Auxiliary Port Replacement: adım 2, 1 resimden 1.
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Axess SPBT1031 Auxiliary Port Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
    FixBot'a Sor
    Yorum Ekle
  4. Axess SPBT1031 Auxiliary Port Replacement: adım 4, 1 resimden 1.
    • Separate the red interface plate from the black face plate by pulling them apart.
    FixBot'a Sor
    Yorum Ekle
  5. Axess SPBT1031 Auxiliary Port Replacement, Auxiliary Port: adım 5, 1 resimden 1.
    • Take the red plate and the motherboard and pull apart them apart.
    • Be careful not to damage the motherboard or red plate as you pull them apart.
    FixBot'a Sor
    Yorum Ekle
  6. Axess SPBT1031 Auxiliary Port Replacement: adım 6, 1 resimden 1.
    • Locate the auxiliary port which is on the left side above the USB drive and to the right of the charging port (auxiliary port has a circular front).
    FixBot'a Sor
    Yorum Ekle
  7. Axess SPBT1031 Auxiliary Port Replacement: adım 7, 1 resimden 1.
    • To remove the port, heat up 5 different solder points using a soldering iron.
    FixBot'a Sor
    Yorum Ekle
  8. Axess SPBT1031 Auxiliary Port Replacement: adım 8, 1 resimden 1.
    Desoldering Pump
    $3.99
    • Use a desoldering pump to remove the liquefied solder.
    • Then pull off the auxiliary port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Elvira Lou Evangelista
975 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G6
3 Üyeler
8 adet Kılavuz yazıldı
5Kılavuz Yorumları
Can you replace with an old phone charging port
Barbara Myers - Yanıt Paylaş
Can you replace charger port with a phone charger port
I did not replace the auxiliary port, what I did is replace the on/off button and this guide help me a lot. Thanks!
Diego Rubi - Yanıt Paylaş
hey, is there a video or something you can make for just the process of taking off the port. For example, showing which exact points need the solder removed. Thanks.
Michael “Mike” Martinez - Yanıt Paylaş
Im not a tech repair guy… I want my speaker to be fixed for me…. Were can i send it to be fixed
jaron curry - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 20,592
