Ana içeriğe geç
Azpen A701 Battery Replacement
Neye ihtiyacın var
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: adım 1, 1 resimden 1.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: adım 2, 2 resimden 1. Azpen A701 Battery Replacement: adım 2, 2 resimden 2.
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: adım 3, 1 resimden 1.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: adım 6, 1 resimden 1.
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Sonuç
Grant Harding
249 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 696
