Ana içeriğe geç
Azpen A701 Charger Port Replacement
Neye ihtiyacın var
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: adım 1, 1 resimden 1.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: adım 2, 2 resimden 1. Azpen A701 Charger Port  Replacement: adım 2, 2 resimden 2.
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: adım 3, 1 resimden 1.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: adım 5, 1 resimden 1.
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: adım 7, 1 resimden 1.
    • Solder and place new charger port.
Sonuç
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
568 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 721
